DD58
- 345
- 63
- Connecticut
Hello to everyone. I just got my self into a mep831a. It’s wasn’t a new idea to me to get a military gen set. I’ve always wanted a mep805 30kw. Any ways the engine run good doesn’t smoke very much little in the beginning then nice and clean. There’s no voltage output to the 3 pins or the courtesy outlets. K12 relay has a green light on it. The electric start works most of the times. Yesterday I unplugged the 2 9 pin connectors off the inverter check the ohms nothing was showing up. Ran the gen set was getting 135vac on 3 different legs. Now I’m not the greatest with an electrical diagram nor a multimeter. But everything else seems to work just right. The preheater secondary fuel pump. There is no fault light on. Other than the low oil pressure light when first starting. I ran it for about an hr yesterday while I was testing voltages so I’m assuming if there was moisture egress into the inverter it should have been gone by then. The only thing that bothered me is the gen set is from 2002 and the inverter is from 2007. So to me that means it was changed. Not sure if there’s something underlying causing it to go bad. I look forward to learning a lot on here and I’m sure this won’t be the only piece of military hardware I have to explain to the wife. I’m the near future.
