Military Standard Engines and Gen-Set Electric Generator Parts of Saturn Surplus Now being offered by Eastern Surplus
country
380
Feasterville, Pennsylvania
We will be inventorying these parts and have them online shorty
ANNOUNCEMENT ! Saturn Surplus Inventory | Military Standard Engines, Engine Parts and Gen-Set Electric Generator Parts from Saturn Surplus
ANNOUNCEMENT ! Eastern Surplus & Equipment Co. acquired all US Government surplus parts relating to Military Standard Engines and Gen-Set Electric Generator Parts of Saturn Surplus of Millersburg, PA
NSN #:
$0.00
country
380
we have about 200 SKU's online already
more being added daily
Mil Standard Gas Engine Parts
Gasoline Engine Military Standard Models
Generators - Pumps - M274 Mule
1A08
2A016
4A032
2A042
4A084
country
380
July 2024 Inventory Update
We now have 287 Military Standard Gasoline engine parts in stock online. abut 200 more items coming soon. https://www.easternsurplus.net/PartsList/1455/Engine-Military-Gas-MSE/1
We now have 329 Parts applicable to M274 Mechanical Mule 1/2 ton in stock and online: https://www.easternsurplus.net/PartsList/1382/Mechanical-Mule-Half-Ton/1
EASTERN SURPLUS & EQUIPMENT CO.
Toll Free: 1-855-332-0500 | Worldwide: (215) 332-0500
Page 1 | Items 1 to 30 of 287
MSE-030 | Bellows Parts Kit for Governor Control Housing Military Standard Gasoline Engine 1A08 2A016
Bellows Parts Kit for Governor Control Housing Military Standard Gasoline Engine 1A08 2A016 Generator and Common Application
NSN #: 2990-00-929-3472, 2805-00-929-3472
Part #: 13214E8189
Price: $5.00
MSE-174 | MSE-174  Oil Pan Cover Military Standard Gasoline Engine 4A032 (7).JPG
MSE-174 | Oil Pan Cover Military Standard Gasoline Engine 4A032
NSN #: 2805-00-103-5320
Part #: 13206E0292, ERKA545
Price: $5.00
MSE-190 | Oil Pan and Check Valve Body Assembly Military Standard Gasoline Engine 2A042 Gen-Set 5 KW
Oil Pan and Check Valve Body Assembly Military Standard Gasoline Engine 2A042 Gen-Set 5 KW Generator and Common Application
NSN #: 2805-00-865-6320
Part #: 13206E0721,13206E0755
Price: $30.00
MSE-192 | Fuel Sediment Bowl Gasket Seal 2 Inch Diameter Military Standard Gasoline Engine
NSN #: 5330-01-198-3496
Part #: 15-1
Price: $4.00
MSE-179 | MSE-179  Slave Receptacle Bracket for 2A042 5KW Military Standard Gasoline Engine (2).JPG
MSE-179 | Slave Battery Jumper Receptacle Mounting Angle Bracket for 4A032 3KW 2A042 5KW 4A084 10KW Military Standard Gasoline Engine
NSN #: 6115-00-418-4754
Part #: 13213E4256, 004184754-98306
Price: $21.00
MSE-177 | MSE-177  Angle Bracket for 2A042 5KW Military Standard Gasoline Engine (9).JPG
MSE-177 | Slave Battery Jumper Receptacle Mounting Angle Bracket for 4A032 3KW 2A042 5KW 4A084 10KW Military Standard Gasoline Engine
NSN #: 5342-01-165-6777, 5340-01-165-6777
Part #: 13211E6707
Price: $21.00
MSE-178 | MSE-178  Connector Bracket for 4A084 10KW Military Standard Gasoline Engine (1).JPG
MSE-178 | Slave Battery Jumper Connector Bracket for 4A084 10KW Military Standard Gasoline Engine
Part #: 72/5048
Price: $21.00
MSE-123 | Timing Gear Parts Kit Cover Military Standard Gasoline Engine 2A042 Gen-Set 5 KW
Timing Gear Parts Kit Cover Military Standard Gasoline Engine 2A042 Gen-Set 5 KW Generator and Common Application
NSN #: 2805-00-221-8649
Part #: 13215E3823
Price: $59.00
MSE-112 | Regulator Engine Generator Regulator Assembly Military Standard Gasoline 2A042 4A084 M274 Mechanical Mule
Regulator Engine Generator Regulator Assembly Military Standard Gasoline 2A042 4A084 M274 Mechanical Mule Generator and Common Application
NSN #: 2920-00-966-9169
Part #: 13206E0813
Price: $38.00
MSE-067 | Cam Shaft with Gear Military Standard Gasoline Engine 4A032 M274 Mechanical Mule
Cam Shaft with Gear Military Standard Gasoline Engine 4A032 M274 Generator and Common Application
NSN #: 2805-00-867-8766
Part #: 13206E0120
Price: $62.00
MSE-073 | Crankshaft Military Standard Gasoline Engine 4A032 M274 Mechanical Mule
Engine Crankshaft Military Standard Gasoline Engine 4A032 M274 Generator and Common Application
NSN #: 2805-00-867-8761
Part #: 13206E0081
Price: $119.00
MSE-004 | Camshaft with Gear and Axle Kit Military Standard Gasoline Engine Gen-Set 1A08
Camshaft with Gear and Axle Kit Military Standard Gasoline Engine Gen-Set 1A08 Generator and Common Application
NSN #: 2805-00-575-3503
Price: $21.00
MSE-056 | Rotor Electric Generator 1.5 KW Generator Military Standard Engine 2A016
NSN #: 6115-00-903-4772
Part #: 13214E0202
Price: $59.00
MU-103 | Engine Oil Filter Military Standard Gasoline Engine 2A042 4A084 4A032 M274
Engine Oil Filter Military Standard Gasoline Engine 2A042 4A084 4A032 M274 2A042 - 4A084 - 4A032 - M274 M274A2 equipped with A042 Gasoline engine, 2 cylinder, 14 HP, Air cooled
NSN #: 2940-00-580-6302, 4330-00-922-0241, 2940-00-933-5673, 2940-00-831-7314
Part #: MS35802-1
Price: $14.00
MSE-095 | Oil Pump Spur Gear for Lubrication System Military Standard Engine 2A042 M274 Mechanical Mule
Oil Pump Spur Gear for Lubrication System Military Standard Gasoline Engine 2A042 M274 Mechanical Mule Generator and Common Application
NSN #: 3020-00-570-2896, 3020-00-868-0889
Part #: 13206E0716
Price: $5.00
MU-254 | Push Rod Lifter Hydraulic A042 Gas Engine Engine Mule M274
Engine Hydraulic Push Rod Lifter for Mechanical Mule Platform Utility Vehicle 1/2 ton 4x4 M274 M274A1 M274A2 M274A3 M274A4 M274A5 Equipped with A042 Gasoline engine, 2 cylinder, 14 HP, Air cooled
NSN #: 2805-00-784-3686
Part #: 13206E0580
Price: $5.00
MU-164 | Piston and Connecting Rod Kit Military Standard Gas Engine 2A042 Gen-Set 5 KW M274 Mule
Piston and Connecting Rod Kit Military Standard Gas Engine 2A042 Gen-Set 5 KW M274 Mule Generator and Common Application
NSN #: 2805-00-867-8752, 2508-00-867-8752
Part #: 13206E640, 377020C, 13206E0640
Price: $9.00
MSE-099 | Carburetor Parts Kit Zenith Military Standard Engine 2A042 4A084
Carburetor Parts Kit Military Standard Engine 2A042 4A084 Generator and Common Application
NSN #: 2910-00-966-9134, 2910-00-966-9135
Part #: 13214E8200
Price: $29.00
SP-3089 | Connector Switch Cable Assembly for Breakerless Ignition Generator Model 2A016 1.5 KW 4A032 3 KW
Connector Switch Cable Assembly for Breakerless Ignition 2A016 1.5 KW 4A032 3 KW Gen-Set Generator and Common Application
NSN #: 5995-01-137-5494
Part #: 13226E0933
Price: $5.00
