scottmandu
- 35
- 28
- Texas
I'ts going on a 3116 with an injector rack travel mod. I'll do 350hp injectors at a later date.Nice, is that going on one of your A1's or the 3116? More boost? How much?
Im not sure. On the 5.9 cummins this same turbo is producing full boost at 2200 rpm. If it does I have a plan to speed up spool time.Will it take longer for the turbo to spool?
injector rack travel mod; If one chooses to go with turning up the engine here is some info. how. More similar info is out there; just search. Figured it be helpful to have a few linked into this thread. Hope it helps others.I'ts going on a 3116 with an injector rack travel mod. ....
What's the factory boost? 60 psi sounds like a lot, though I'm not too familiar with these engines.I'ts going on a 3116 with an injector rack travel mod. I'll do 350hp injectors at a later date.
Turbo efficiency is good at 60 psi with about twice the flow as the stock turbo
