3dubs
- 3
- 0
- Houston, TX
CUCV FAQ Article is great and I love that I can quickly find the TM's but one needs to be added. TM 9-2815-237-34 it covers working on the IP and much more.
If you have it in PDF, link it here and I'll see if I can get it uploaded.I have TM 9-2815-237-34P but I am not authorized to upload it to the TM's.
It covers HMMWV and CUCV 6.2 and 6.5. It is really helpful. It will also help if you get a HMMWV engine and put it in your CUCV. I was trying to replace O-rings on the throttle shaft of the injector pump. I looked at it and thought I figured it out but did not want to break anything. After searching the CUCV TM's I went to the internet and found the other TM and it explained very part of rebuilding the IP. I found that I was right in what I thought would work. But I figured it could help other people too. It explains pre 1990 or 1990 on. It is not CUCV specific but it covers the engine down to much more detail. I like how it tells you in each section what tools you will need.is that the hummer's engine?
