deepseeman
- 0
- 6
- San Diego, ca
So here it is. I have been driving my truck without problems for quite awhile. All of a sudden I go to start her and I barely get anything. The starter turns over slower than molasses. When I turn on the ignition All lights are bright excep gen #2 and my voltage gage barely moves.
So here are the things I have done;
load tested the batteries-good
replaced starter wires
checked fuses
cleaned battery terminals
tested starter-good
both batteries 12+ volts
26+ volts at starter
checked for any loose wires and found none
I was thinking about replacing the starter relay switch(1559171, but I have power to the solenoid. Isnt that switch all or nothing?
I am at a loss an need to get this fixed by Monday. Any help is appreciated.
checked fuses
tested starter-good
