jaybird67k
- 25
- 28
- Texas
So I seen the video from Callmecolt and just wanted to confirm this is a needed mod for the MEP-803 A.
Thanks, Jason
Thanks, Jason
Thanks. I just ordered the parts.Yes it's needed.
Without it you risk burning out the stator in the gen head.
It's to protect the gen head if the VR fails and shorts out. A design flaw in the factory VR.
Thanks, I found the fuse holder and fuse and it will be her next week as well as an upgraded fuel tank drain bulkhead fitting I got from Colt.I'd wait until the Fuse Mod is installed.
Not worth the risk of burning up your gen head.
I wouldn't run it until then.
Is there any other mods besides the fuse and holder and the veristor that I need to do?I'd wait until the Fuse Mod is installed.
Ok so that's the part that gets damaged and kills the generator section.That picture is of the circuit board inside the VR. Circled items are the diodes that can short out damaging the Quad winding and wrecking the gen head.
I just ordered a kit from you. If you could rush it that would be awesome. I don't mind paying for that.The MOV (varistor) I provide in my kits is a 14D151K
Being a holiday weekend the package won't go out until Tuesday when the post office opens. I'll ship it Priority for you.I just ordered a kit from you. If you could rush it that would be awesome. I don't mind paying for that.
Thanks, Jason
Thanks Kloppk.Being a holiday weekend the package won't go out until Tuesday when the post office opens. I'll ship it Priority for you.
Ok Thanks.The fuse mod protects the gen head from being damaged if the VR shorts out. The Varistor (MOV) helps protect the VR from shorting out.
So... it would probably be OK to load test it with just the Fuse Mod. Just a slight risk of the VR shorting out without the varistor before it's installed.
