you think I could rent a cable for $200/Day?So I am thinking you could rent these out for $200/day...otherwise, you're doing forum-based troubleshooting. Nice Job!!!
I have pretty much of the entire kit, minus this wire.
I have this cable, I also have the entire kit minus cds. I will sell.
I would get a very similar error if I tried to do the initial self test with any cables connected. When I remove all but the DCA and serial cable, I could pass the test, then connect what I needed and it would measure just fine during the actual vehicle diagnostics. What's plugged in at the time of the error?I am getting this messages when I connect the MSD ice box to the Miltope.
Does anyone know why and how I can fix it? Or what causes it? I tested the Ice box as suggested , and there is no short.
Terribly sorry for never replying to this. I hope you found a fix! If you haven't, I'd get in and start testing some things with a separate multimeter. First would be the actual voltage from your vehicle...it's possible if it's low, it probably won't allow your MSD to work correctly. As well, try to see if anything is caught between the contacts on either the cable or any of the sockets, plus try and test if there's any internal shorting on your DCA cable. I'd focus on observing the W-4 cable sockets (I forgot what their J numbers are, as its been a while), as those are what would throw the same error on my kit.Only the DCA and serial cable
Are you still looking for an ice system?Excelsior! I was able to tweak the disc a bit and successfully got the ICE drivers to install. Plugged in the main connector to the STE/ICE port and connected the ICE Box to the serial port on my laptop and was able to feed live voltage data through. I used both the straight ICE tool, and the HMMWV IETM also had success initializing the ICE Box and getting data. I'm really glad to see that the ICE Box and the cables are good to get that connection established. Tomorrow, I'll get some pictures and will try out one of the transducers on something, if I can. Maybe also get LabView up (provided on the disc) and see if I can make use of the analog probes and see how precise they are.
Trying the Dearborn Protocol Adapter will have to wait, as I just don't have anything to test with it. Once I get some of the wiring in for the TCM, I can at least drop on the connection there to see if I can get it to throw error codes at me and show that it works.
Depends .Does anyone have the software that they are willing/able to share?
Depends on what?Depends .
People sell these disks, that’s what it depends on. BenjaminDepends on what?
