- 1,117
- 1,058
- 113
- Perry, FL
Looks like we're on our own here troops!
.I can put you in contact with TASCOM if you want to see if they'll remove them from restriction. They certainly have no problem contacting me when there's something posted up that is restricted.
.Anything changed on the status of these manuals?
.Looks like there might be an issue with the air lockers.
.Got them working!
No sir, it will be a week or so. Once I get it and get it cleaned up, I'll post some up. Thanks for asking!.
So... I have to ask Russ. Has it made it home yet?
Picture. Just one?
What was the issue?Got them working.
They quit again. I'll advise. It will be a few days before I can work on it.What was the issue?
.They quit again. I'll advise. It will be a few days before I can work on it.
I’m looking for the electrical for troubleshooting my rear end lights will not come on everything else as far as the lights works on the front blinkers headlights inside just the rear are not coming on looking for troubleshooting step-by-step guide please thank you in advanceJust now seeing this. Most of the MTVR manuals are on CD in the newer Interactive Electronic Technical Manual format. They did release some PDF type manuals when the trucks first come out. Let me look around when I get to work tomrrow and I may be able to help. I know I can get the IETM version but it takes some getting used to when it comes to navigating those vice the old type manuals. I know I have the operators stuff but I'm sure your looking for the maintenance manuals.
I’m looking for a electrical troubleshooting manual for the MK 23 I could send you my email if the administrators won’t allow you to give it to me I really need help in this area thank you in advanceMost likely it’s a ground issue the rear lights won’t work a few other little electrical problems but nothing else everything else is goodSorry for the late response. To answer a few....
the manual I posted is more of an operator manual
electrical and wiring diagrams are really not available to the average joe. You need an Oshkosh laptop, which we had in the Marines, to really diagnose any real issues. The days of fixing stuff with a light pointer are gone.
I posted the manuals serval times on this board and was told by the moderators that they may take them off. So if they are not on this site then they took them down even though they realease these trucks to the public. To me it is a safety issue and owners should have a manual or they could possibly kill someone.
I was in the Marines for 24 years and just retired within the past year. I grabed a electronic version of the manual while they were still handing them out there disk. Now it’s all laptop and computers to fix trucks.
also, if the ECU on the side of the CAT motor is shot, the truck won’t start no matter what you do. last I check they are a few thousandto replace
.I’m looking for a electrical troubleshooting manual for the MK 23 I could send you my email if the administrators won’t allow you to give it to me I really need help in this area thank you in advanceMost likely it’s a ground issue the rear lights won’t work a few other little electrical problems but nothing else everything else is good
All maintenance manuals for the MTVR are on laptops. The Marine Corps does not have any paper maintenance manuals. The only paper manual the Marine Corps uses for the MTVR is the operators manual.Ok, having a totally impossible time trying to find Oshkosh MTVR manuals. Anyone have any ideas on trying to find some.
THANKS IN ADVANCE!!!!!
