MO MV man
- 4
- 0
- Imperial, MO
Hello all,
I installed the Donaldson M070028 muffler following chgofiveo's thread.
EASY install! I haven't reinstalled the shield yet. See pics.
The Donaldson is a far superior muffler, in my opinion, due to it's robust construction (Heavy Duty!) and lack of packing inside (packing WILL soot up and blow out eventually).
The results? Outstanding exhaust noise reduction!
IDLE: the reduction is amazing. Dropped from 93.1db stock to 82.2db!!
CRUISE: Steady state cruise is quieter:
50 MPH, approx. 1950 RPM was 96.4db stock, 92.4 muffled.
HARD THROTTLE: Nail the throttle at 50 and the difference is phenomenal:
102.6 db stock, 95.5 muffled.
What the db readings don't tell and I need to pass along.....
The Exhaust note:
Oh my.....what a colossal improvement....idle still has the C Turbo whistle but no more drone. Cruising on the highway? Incredible.
Deep, "clean" exhaust note AND......it's such a smooth, clean sound that I can actually hear those big XML's growling now!
Seems the faster I go, the more smooth the note.
To those who might look at that and say, "but that's only 11db......only 4 db....".
db readings are interesting.
A 10db reduction, for example, is HALF the previous noise level!
A 5db reduction is quantified as "a clearly noticable change".
AND....
I have a feeling the readings I took in-cab at 50MPH were also reading the usual Deuce in-cab racket (rattles, drivetrain noise, etc.).
BUT the reduction in sound is definitely reduced.
How I did the readings:
Meter: Extech Model 407768 Sound Level Meter
Idle-standing next to the truck in the same spot, extended my arm with meter in hand to outlet of stack.
Cruise-holding meter in my hand in the middle of the cab, both windows open (it was almost 100 degrees yesterday).
Hard acceleration: Same position as cruise.
The Exhaust note:
AND....
