Multifuel timing?
m-35tom
222
eldersburg maryland
basics are remove the little cover with 4 little bolts on top of the advancer housing. with the fuel shutoff pulled out rotate engine until pointer lines up with line exactly. now read timing on engine front balancer. you should turn engine in the direction it runs and just creep up on the line for most accurate results.
