My 1008 on 37's
blzrgb
mississippi
6". The taller tires take a little gear out of it. Works good on the hyway. Can't really tell any difference offroad.
blzrgb
mississippi
Thanks. The wheels are pretty heavy with the insert's and all but it's worth it. You can run as low of pressure as you want. Makes the truck ride good offroad too.
blzrgb
mississippi
They're 16". The back spacing is about right too. The scrub radius is still at or about factory.
Also, if anyone decides to buy a set, the taper on the wheels where the lug nuts seat is hard to match. I found the right taper on a set of lugs at my local Carquest. It took a lot of searching but i have the part number for the lugs if needed.
