Tons of progress made since last update. I finished up the floor and got the table, two cabinets and two leather recliners, air mattress and fridge inside the truck. I I got the last coat of paint on the outside of the box as well and installed the new reflectors on the truck. I painted the gladhands on the truck, and installed the pyro meter. I wired the gauges under the dash to #27 wire going to the power switch on the dash and they work great. Today I got the truck dialed in with dad with the fuel. Bypassing the fdc made this truck Smokey! After turning it down a bit the truck runs great. Temps don't climb above 1000 degrees and it pulls the same hills as the cargo truck with more weight. Very pleased. I decided to setup the air mattress and found that the mattress needs to go to the front of the box followed by the recliners. The recliners will be moved depending on whether I'm using the mattress or not. Gives me options on the floor plan rather than having a constant permanent mattress. Plan is now to finish up painting the trailer, make a license plate frame, make the radio mount for the cab and then test drive the whole rig on the road to see how it handles. Hope to go to a car show by the end of the month to show off the hard work.
