My Challenging MEP-002a's
LuckyDog
11
Freedom, NH
MEP 002 / 003 Compression test adapter
Jerry,
Any luck with the compression tester / adapter? I was working on my MEP002a over the weekend. Guy at the shop couldn't find an adapter to fit the glow plug. We measured the threads at 7/16"x24.
What have you found out?
I only need an adapter. Have all the other parts.
--Paul
Crawdaddy
Louisiana
Received my compression tested from harbor fright today. am working all through the weekend but expect to test monday and tues. got the unit running but very rough. Obviously needs a valve cover gasket to replace the one I just replaced and damaged.
jerry
Jerry, are you able to confirm if the 12 piece diesel compression tester from Harbor Freight has the required adapter to test the compression on my MEP-003?
