Joeinderry
- 1
- 0
- Derry/NH
I know you're all getting sick of fuel issues but heres mine.
Bought a deuce (multifuel), it wasn't running but I don't mind challenges. It had sat for probably 10 years not run. Got it home and sprayed some ether in it, it started and stalled. Opened up bleeder, no fuel. Fuel pump was in pieces in tank. Replaced fuel pump. Bled system. Still would not start. Checked fuel stop under the cover and it moves freely. Changed all filters (they weren't horrible looking). Turned on fuel pump heard what sounded like a kinked hose. Found the copper fuel line that comes from the primary filter to the secondaries crushed flat! Hows that happen? Replaced it. Bled system still no start. Tried more ether but just starts and stalls. Disconnected fuel lines from injectors, no fuel coming out while cranking. Took cover off the fuel shutoff and looked inside while my daughter cranked, could see the gear inside spinning. Pulled fuel line off injector pump (one that goes to the top of the injectors with the in tank pump on fuel flowed). Tried one more time with ether and it started and stalled. Any ideas from here. Any pictures of the injector pump with descriptions of the parts that I will be looking to test. What is the HH? Thanks for any help.
