Hey yall, Im still very new to Deuce ownership, so my guess is that is something stupid, but I wanted some input and suggestions before I go and muck it up worse.
Yesterday I completed the first oil change on my truck, along with forum member Barneyszoo (Phil)s help, and then we filtered the old oil and dumped it into the tank that was about 1/3 of the way full of Diesel. We all fixed all the lights on the truck, so I decided to take a bit of a test drive this evening. Now its giving me fuel issues.
This was the first time I drove the truck after dark, with the headlights on. Started fine, but then was sputtering a little bit on a small hill. (2000 RPM, 5th gear) At first this was not a big concern, but it got progressively worse. When we got off the freeway it died at the light, and didn't want to start back up. Shortly after that we had traffic lights on small uphills and even in low range 1st it wouldn't move, and would die when I tried to change gears.
When I arrived at my destination I let it sit, the engine cooled, and it drove to the freeway just fine, but it wasnt long before on the slightest hill it was sputtering and struggling to maintain 50mph. My thoughts went to the fuel being too thick from the WMO, didnt seem like we had enough to make the difference, but just to be sure I pulled over and added 5 gallons of unleaded fuel, I was 100% that would thin it out enough. On flat surface streets it would accelerate to speed just fine, but when I got back on the freeway I had to fight to keep speeds of 45-50, and you could hear the turbo spool up after each time the engine sputtered.
I did finally get it home, and I noticed that if the fuel pressure was given a chance to rebuild pressure, for example keeping my foot out of it and the engine in gear as I gradually slowed to a stop, the engine wouldn't die when I put the clutch in. This is a new problem, when I drove the truck to my house (70 miles) we had to go over a mountain pass and I had no power troubles at all.
The upside to all this is that I got a lot of good practice downshifting and double shifting (I think that's the term) and my roommate got a kick out of the fact that when I was loosing power in fourth, instead of going to third I went to low fifth, which made the next downshift easier and kept me more in the power.
To sum it all up, progressively worse throughout the evening, the truck seemed to be having issues maintaining fuel pressure. This resulted in failure to idle when leaving the freeway, and surging power. Refused to start on a hill.
I have theory's:
- If you do not want to read the whole explanation, but you have something to contribute, then skip to the Bold section.
I have theory's:
- The WMO made it too thick, or has clogged something up.
- I added 5 gallons of unleaded to combat this, with no success.
- The electronic fuel pump is not getting enough power with the lights on.
- Ill drive it tomorrow in the day light to see if there is any difference.
- The fuel pump/fuel filters/injection pump is clogged or failing.
- I have not done fuel filters yet, does anyone have the Napa parts number for them? How much are they? Can you point me to the section of the TMs that deals with servicing the fuel filters?
