- 6,522
- 13,851
- 113
- Hawthorne, NV.
They are 12/24 VDC, I am sticking with white lite and using the red lenses covers for the dash lights. I will probably change the rest of the indicator lights (brights, air etc) to LED if these look good but its kinda pointless to make those brighter.Are your LED's 24 vdc? I have some manual dimmers and remote controls for the 24 vdc, if you need to tame your brightness down a bit.
I have some of the LED (green, red, white) strips that can be cut + the ends to make a series, like 4" or 8" pieces of LED strip with 30" of wire and another LED strip, so all of the gauges have some indirect lighting behind the dash and maybe some passenger lighting.
Do you have shifter boots? Big improvement against heat.View attachment 737851
Got her home, pix and info to come, she almost killed me on the drive home in the TX heat.
