DCIV
- 0
- 0
- Morristown, TN
It wasn't in any of the pictures, maybe all humvee's have them and sorry for the picture it was at night but I wanted to get it to you.How about a picture of the "com" box. In fact pictures of your truck in general. Congrats.
I took a video and sent it to someone, I will upload it and get you something so you can tell me. Quick question on the hubs, my jack isn't rated to pick up the humvee, I have seen youtube videos of people doing it but they always have the wheel off, do I need to take the wheel off?Congrats on your purchase.
The belts do dance a bit, mine have been like that for a year, the horn is located near the front diff, just crawl under and you you see it.
I drive mine nearly every day, but before I did, I spent quite a few hours checking everything.
The best thing to do is to change all fluids, engine oil/ coolant, trans, diff and hubs, etc...
I replaced all of the lights on mine, most of them had rust, no more issues.
It's a fun toy, if you maintain well, it is very reliable, like I said do all of the maintenance first and then just do the upkeep and you will have a great time
I am leaning towards the batteries being the cause of the surge actually, I am going to replace those on Sunday. If that doesnt work a fuel filter is next and sounds like I should just order two or three. Thank you for the advice!Congrats on your new toy.
If you belts dance more than normal, a video would be nice hint hint, make sure to check that your power steering bracket is intact on the lower adjustment slide. Another thing to check is that the 'b@stard washer' is mounted correctly on the back bracket on the alternator.
If your horn doesnt work with the light switch on, its easy enough to remove the pickup contact from the steering column, its only 2 skrews. Clean it with emery cloth on the shaft if you see any corrosion, and you can bend the tab just a little to make it rub better. While you have the pickup dismounted, touch it to ground to verify the horn in fact does work correctly. if that doesnt work, and the horn works by grounding the pickup out, take out the horn button, and check that the wire is connected to the button, might have to dig out the wire from the column with a dental tool, just dont pull it too far out there isnt much slack.
Fuel filters, fuel filters, always keep good clean filters in, and always carry at least 1 spare. That is always the first place I start on a surge or stuble, next was addressed with the water in fuel tank and old fuel. Diesel fuel is good for a few years with no water and no addatives.
