- 3,871
- 497
- 83
- Gray Court SC
Check drive shaft are clocked right. If somebody removed them and didn't put them back correctly they could be off.
By noisy I was basically saying that this isn't like my modern daily commuting vehicle, which is quiet enough to hear every little mechanical change. These trucks are so loud you almost have to wear hearing protection, you have people here on SS installing sound insulation in and under the cab, etc.Thanks for the feedback! Your comment that the truck has "all that noise and vibration" may be a further clue that you do have some underlying issue unique to your truck (considering your results, my comment is "well duh"!). Other than a little drive-line chatter occasionally, mine is not particularly noisy.
Is there an opportunity for you to ride in another FMTV for comparison?
Awesomeness, where did your engine block break?
Is there a process in the manuals for checking/setting the clocking? I know for a fact the driveshafts have been off, so this sounds like a great place to look. I didn't even know clocking them was a thing.Check drive shaft are clocked right. If somebody removed them and didn't put them back correctly they could be off.
Thanks, I'll check them.The driveshaft yokes, both front and rear have to be lined up or parallel. There isn't a master spline so they can be put in wrong very easily. The front and rear yoke on each driveshaft have to be aligned as you're looking down them, not 90 degrees or whatever from each other. They were supposed to be marked before removal the first time.
Very likely the problem. I have repaired 2 LMTVs that had out of phase driveshafts. It's easy to miss unless you look for it. Sets up brutal torsional vibrations in the driveline depending on how far out of phase they are.Check drive shaft are clocked right. If somebody removed them and didn't put them back correctly they could be off.
Ok that's great advice. I finally found the parts list in the TM so now I can identify the bolt sizes.The water pumps come from CAT unpainted (for whatever stupid reason). So if someone replaced it previously, and was lazy, you'll have that. The can of CAT yellow paint is like $20... I had to buy it to paint mine (and then wait an extra day to install it until the paint dried).
Yes, M8 sounds right. While you're at it, I would replace all the bolts in the alternator bracket (to the block), and that little L-shaped bracket (to the alternator bracket), too. Blue Loctite 243 them. If the bolts got beat up while things were loose, or stretched, you'll have issues with it all coming apart again.
Where do I get that magic yellow paint?The water pumps come from CAT unpainted (for whatever stupid reason). So if someone replaced it previously, and was lazy, you'll have that. The can of CAT yellow paint is like $20... I had to buy it to paint mine (and then wait an extra day to install it until the paint dried).
