- 501
- 29
- 28
- Kingman AZ
Ok, so I just got back into town the other day after being gone for a week. The truck sat the whole time I was gone. When I got back the truck would not start. Cranks and cranks with some white smoke, but will not fire. Went through the TM religiously, checked GP's and relay (it's warm enough that I shouldnt need them anyway), changed fuel filter, bled system, checked lines, etc. I finally replaced the fuel lifter pump. No go. Same symptoms.
I'm now highly suspicious of the fuel. I plan to siphon out the fuel and replace with straight diesel. What is in there is mostly diesel now, though. The last time I added WMO it was a 40/10 mix. It was starting hard and had a slight lack of power at take-off so I ran that down to about 1/4 tank and topped off with D2, ran it a while then parked it before going out of town.
Can diesels flood?
This is NOT good! Have you tried bleeding the injectors at the head? See if there's fuel to all rails? Keep us posted.
