fox3344
- 0
- 0
- sw michigan
Hi everyone, I'm working on a 86 M1009 with a hard shifting problem. I searched the many posts and have tried several of the suggestions given, there's lots of knowledge here.
This is where I'm at so far.
-vacuum lines are all new, double checked the hard line to the modulator, even ran a new vacuum hose to eliminate it for a test.
-I eliminated the rubber block at the vacuum regulator and hooked the two lines up direct, top port to the trans lower to the vac pump.
-vacuum pump seems to have sufficient pressure (no gauge as of yet)
-adjusted the vacuum regulator all the way back towards the firewall
-has a new red stripe modulator, adjusted out.
-I ran a hose directly from the vacuum pump to the modulator, plugged the port on the regulator, just for a test to see if it would shift any sooner.
All of which made no change, the truck shifts hard and at high rpm. If I let off the gas it just hangs in gear. The fluid is clean and full, and all tests were at operating temp.
I haven't taken apart the vacuum regulator to clean it because I figured by hooking a line directly to the vacuum pump it would eliminate that as a potential issue.
Hopefully I'm missing something else here.
Any info would be appreciated.
--I'm still going thru the manuals as well!
Thanks, Andy.
![Banging Head aua aua](https://www.steelsoldiers.com/images/smilies/icon_smile_banghead_125.gif)
Thanks, Andy.
