DinoShepherd
- 0
- 0
- Sisters/OR
1990 m923a2. Ft. Lewis rebuild in 2012. Very nice shape. Slowly piecing together the little stuff uncle sugar missed.
When I got it, it had a chirp under the hood at idle. It would also squeal like a pig under power, uphill at over 1900rpm uphill only. Not through acceleration at that rpm, Only under heavy load. This may be a clue.
Water on the belt would make the chirp go away at idle. I changed the tensioner and belt. No more chirp at idle. Happiness.
The squeal that sounds like belt slipping is still there under heavy power, uphill is still there. But I am thinking it may not be related to the belt. It goes away when I back off on the gas a bit.
Is is it possible it has something to do with fueling or turbo? It really does not sound healthy and is quite loud.
Thanks in advance. BTW, I checked the TM and it said to ask you guys.
