Are you talking about a Yellow & Purple with a white stripe or Yellow & solid Purple? I have seen Yellow & solid Purple, but not Yellow & Purple with a white stripe. The Yellow & Purple with a white stripe is the one I am looking at.yep just went out to my truck, i wasn't able to see the other wires. it is Neutral safety next to backup. I had to move a lot of wires to the side in order to see it
Could be the "in 10 sec. SELF DESTRUCT wire upon connection"I guess, if everything works with it unplugged, them leave it alone!
I thought about that when I read post#1, but since I am a KINDER-GENTLER person today, KNOWING how some get there feelings hurt VERY easy, I decided to lean to the SAFTY commentYou dissapointed me with your reply, Ron.
I thought for sure, you'd post it was the wheel-chock tether...
Ah, HA! You might be on to something. Just tried it and it cranked while in drive. Might go to the Neutral safety switch!Will your truck crank/start with the gear shift in a position other than Neutral or Park?
EDIT, If I feel the KINDER-GENTLER wareing off. I might have to come back an EDIt
Does goAh, HA! You might be on to something. Just tried it and it cranked while in drive. Might go to the Neutral safety switch!
Hey Doghead, can you please give me the TM reference for that Neutral safety switch you have the pic for? Your pic looks nothing like the switch at the bottom of the steering column right by the firewall (back up light switch). Are you saying there should be another switch there too? A back up light switch and a Neutral safety switch?Ok, so it must be the neutral safety switch. It should plug into the same switch unit as the backup lights(The TM calls for the switch shown in the pic I posted below). Look at this pic, it would go on the top left 2 terminals.(cooper colored) But my truck had a plastic cover on those 2 terminals(and I don't see the 2 wires and plug shown in your picture in the first post).
Nope, no go. The switch (back up light switch), already has a plug to it. Two blue and one green wires.Does go
