Need a 4500 lb. Vehicle Transported from IN to CA - Can anyone help?
harrison987
Los Angeles
Hey guys!!!
I need a NON-RUNNING WW2 German Tracked vehicle, as well as a cannon, moved from Indian to California...
Anyone out there who can help or refer?
Been getting some crazy quotes from large companies... :(
TIA!
Mike
harrison987
Los Angeles
Hi!
Thanks for the reply!!!
Vehicle is approx. 4500-5000 lbs or so. Width is 6.5 feet, height around 7 feet...length is 14 feet approx.
Cannon is small ...300lbs.
I have attached pics of both.
Would need some way of getting it onto the trailer though.
It has a front tow hook...and I may have access to a forklift...just not sure of how to go about it.
Ideally, a winch would have been perfect, as it could simply be pulled onto the trailer...
Thoughts?
simp5782
Feo, Fuerte y Formal
9,368
Mason, TN
If it is around Indianapolis I know there is a member or two with a 925 in that area. I am sure they would be willing to help to take a peak at that thing. Check the member map.
NV555
Ely and Vegas Nevada
Those are about the same load out numbers as the M998 should fit on well. 98G Has moved a lot of stuff around I'm sure he has some good plans in the works already! Might be a good idea to tarp it as it will be drawing a lot of attention going down the road!
Very cool though thanks for the post!
royalflush55
529
Reydon, OK
Secure a snatch block to the front of the trailer with a chain. Fasten a cable to the tank then run it thru the block and get along side the trailer with another truck or tractor and pull it on. Same as a winch. Just make sure all components are rated for the load.
