dzmedia
- 0
- 0
- Pacific MO
Anyone know where i might be able to find an air filter before this weekend in or around st. louis?
Thanks in advance for your help
69 m35a2For what ?
Thank youTry Brent @ A1 Army Supply, 414-531-9772, He can probably get one out to you.
True but i thought i would get more views on a new thread in the correct forum.If you had simply posted this on your other thread, it would make more sence.
This one has no filter. It is one i am going to pick up.If its 'clogged' did you clean it per the TM? They are washable.
For what ?
http://www.steelsoldiers.com/requirements-new-members/70098-hello.html
Yes, that thread. They would know because they would read it. If they already had read it, when they click on the little arrow, it takes them to the newest post.
That thread can also be moved to the Deuce forum.
either way, they all are on the main page.
You didn't post the information on the in this thread till you were ask without that info this thread is worthless. The attachment is something you should save to your computer . It dosen't list the air filter cross but it has much of the information you will needWhat? So I should have posted a request for information on a part location in the "requirements for new members forum" and not the forum specific to my request/vehicle forum?
I dont seem to understand that. How wold someone that has seen my "hello" thread bumped on the main page know that within that thread i posted a new question asking about where i could source an intake locally?
You get no brownies or points, the OP asked a question. Back to our regu......Do I get brownie points for 'enforcing the rules'?
What is the correct part number?That air filter listed in the cross is NOT NOT NOT the correct one. I made that cross back in 2004/5 and I found that number. but here is the problem.. it is rated for 270 ish CFM. The multi filter is rated for 410 CFM. I have installed that wix filter and the truck will run/drive but power will be lower and EGT's will be a lot higher.
