Woodsplinter
- 6
- 18
- Phoenix/AZ
Looking for one to change out the IP on my M35A2 multifuel. Anybody know a current source for one?
Thanks!
Thanks!
LOL, YES, that was me (among others)...I'll never do THAT again!it is almost that easy, but many people continue to get the timing 180° out!
The engine either won't start at all (like mine), or it will stumble & run terribly. Trust me, there's only one reason for that once you remove the IP: you are 180-degrees off. You MUST remove the forward valve cover & verify the valve positions before you reinstall the IP to ensure proper timing.What happens when the timing is 180 degrees off?
hard to start, black smoke, runs poorly, low power.What happens when the timing is 180 degrees off?
Tom,you only need the wrench to take the IP apart. to remove it from the engine, just take out the 3 bolts after you have aligned ALL the correct timing marks.
why are you taking the IP off? it is easier to just replace the HH since that is 99.99% all that fails.
It might still run (especially if you shoot some starting juice in the intake) but it will blow gray smoke and not idle. Spoken from experience from my first IP replacement when not reading the TM closely enough.What happens when the timing is 180 degrees off?
