- 1,180
- 162
- 63
- Marietta, Georgia
Hi guys, new to this part of the site.
I need some halp with a genser (3kw/4A032). Got her running, makes power to full load, just REAL noisey, and vibrates a LOT. Seems like the timing is off on the firing. It has the -3 electronic ignition. How do you set the timing with that system?
All four cylinders run, and it will run on any combination of two, but it is just not smooth.
Compression is good on all cylinders, new gaskets and hoses on intake, new carb.
Any suggestions will be appreciated.
Squirt Truck
Squirt Truck
