Need help removing some parts
panzerjunky
san diego ca
Can anyone tell me how to take the seat cushion of the upper fold down part of the passenger seat (the part you stand on when the M66 is in place) I can see no screws or nothing is it glued on?.aua
Also on the throttle and engine shut down handles how are they removed and I guess while I am at it the heater controls as well so I can get the new label plates under them.
Thanks Jerry
ARYankee
33
Benton, AR
It is some what crimped in place. At least mine was. If you look at the seat with it upright, look at the top of it where the frame is, it is slightly bent in to hold it in place. What I did was used a large screwdriver to pry it out.
As for your other questions, I don't know but I do hope I helped.
SCSG-G4
PSVB 3003
3,379
Lexington, South Carolina
Engine Shutdown has a very fine thread nut on the back side - takes forever to loosen and tighten back up. Much easier to remove the light switch first, to get a bit of room for the wrench, but even them be prepared for a lot of turning. Most of the time its' an 1/8 of a turn, then reposition the wrench, another 1/8 of a turn and repeat - did I mention it's fine thread? Never have done the throttle, but it's probably the same way.
