Erik Jenkinson
- 8
- 18
- Metairie, LA
I have a sound like a vibration of a loose bolt etc. That only occurs in low rpm, just above idle, and stops at "cruising" speed. I think it may be coming from the injection pump. My reading tells me that injection pumps usually leak upon failure. Is this sound common to a failing ip? Or should I keep digging? I have throughly searched for anything obviously loose with no luck. My stethoscope is definitely leading me to believe it is the injection pump. Is this what a worn timing chain sounds like?
