Ok, so I went and looked at a M35 near my house today. It don't know what year it is but I do know it is in great shape with the exception of a few small flaws. It has a hard top, winch, interior heater, air front axle, springer seat. The truck hadn't been started in a month and he flipped the ignition switch, hit the starter button and it instantly started and purred like a kitten. I then drove it down the road and it ran great. It shifted great and easily hit 50 mph on open flat road. The only flaws I saw were one headlight not working, and the blinker module is burned out I guess. The antifreeze was bright green, and the oil looked, well like oil. It had 40 psi of oil pressure at idle and then after I drove it it went way up 90+ psi. The air pressure was at 90 as soon as it was started ( and since it hadn't been started in a month I pressume there are no looks, also I drained the inboard tank after our short trip and there was a little water in it, not rusty looking though. I couldn't get the other petcock open though...). The brakes felt great and the ebrake worked. I didn't try the winch or the front axle engagement. It has the canvas top and sides? and the top (bows?) seemed really tall. Anyways there didn't appear to be any major leaks, the front axle seals seemed to be seeping just a little bit. That doesn't seem bad. The motor was dry, no leaks anywhere except maybe a little rear main seal seepage. So basically...what I want to know is how much do you think it is worth? Pics below. D
