tilac999
- 0
- 0
- Boston, MA
Looks simple enough. I'll start looking. Your motor looks great. I that a 4bbl intake manifold I see?
Why so big? Fire dept. Flashers, Sirens, radios, etc.200amp, definitely not a bolt on. Bracket fabricated. Why so big? No idea.
Most likely. I'll live with it. Works fine. Wonder if it's hard on the factory voltage regulator?Why so big? Fire dept. Flashers, Sirens, radios, etc.
these were the factory figures for 360 with thermoquad****, that looks great. What are the HP/torque specs for that 360?
360 | 4-barrel. | 220 hp @ 4,000 | 280 lb-ft @ 1,600 |
Put it in another gear then P or N, and try to start???Neutral safety switch works: only will start in P or N. How to test?
Also, horn works but has been by-passed via button on dash. I pulled the cover off the steering wheel and the switch looks OK. Is the steering column supposed to have a ground coming off it? How can I get the horn to work properly?
Thanks.
