New Mdl CD-10516 key question
rpellicci21
Manorville, NY
I'm sure this has been posted already but i havent found much on it.
I recently bought a 1985 Mdl CD-10516 from government liquidation. I know that most of the M series keys are universal. I haven't found much on the mdl CDs. i was wondering if it is the same key for the CD series as the M series. Or is it also considered part of the of the M series because of the "Mdl"
Another question is when towing the 4x4 CUCVs is it enough to put the transfer case in neutral or should the drive shaft be disconnected to be safe ? Any insight would be helpful thank you
Glockamolie
Houston, Tx
Per the manual you can flat tow with trans and TC in neutral up to 50 miles safely. That said, it'd be better to take the 10 minutes and pull the DS.
1,808
CD10516 is the M1009. All of the CUCV family of vehicles use the same key. Most of the bigger M series don't use keys. FYI the blank is a B49 and the code is 73Y2. If you need one, PM me.
rpellicci21
Manorville, NY
Thanks guys for all the help. I have to try to get down next week to pa to pick up my new cucv. pretty inconvenient times to come pick it up as im sure you guys know
LanceRobson
206
Pinnacle, Stokes County, NC
rpellicci21
Manorville, NY
I decided on just spending the extra 20 bucks and rent car trailer from uhaul. Hopefully going down thurs to get it hopefully when I throw in some batteries it'll start up
