Thanks for the advice on the bumber numbers, I can just make out US Army and some numbers on the tailgate, I'll investigate further this weekend.
I bought the truck for the GSA lot in Lebanon Missouri, I transported it to Columbia on a roll-back truck on Friday. I put a battery in it and it fired right up. I took it around the block, and ran it through all the gears with no problems. The guy at the surplus lot said it had been there for about 6 mos, and spent the last few years as a Brush Truck for the Conway Rural Fire District. It has the original motor, tranny, etc. It has an after-market electric fuel pump and is now 12 volts. The top is shot, as is the seat covering and tires, but only has a little surface rust in the bed. I paid 2100.00 for it, not knowing if it ran or not. I went down and looked at it last month. At that time they also had a couple of Kaisers and a 1950s M38 on the lot.
My buddy is coming over this weekend to pull the carb for me and give the truck a good once over. He thinks I pulled some grit into the carb, and it should be an easy fix..
Chris
