llong66
- 2
- 0
- kokomo, In
When I bought my 85M1008
i was told it had a newer <5000K miles on it 6.5. Well I have had nothing but problems, before I even got 50 miles I got a low coolant light, puled over and the water pump was gushing water, so that had to be replaced and I think it had previously been over heated as one of the heads was cracked so I replaced them. However, one of the cylinders was scored, probably from over heating and is below the standard compression and smokes until warm. The guy I bought it from had told me it started hard when warm so I was figuring I was going to need a new injector pump. When I had it looked at the pump was fine but was only held in place with one bolt, obviously, whoever did the swap didnt now jack about these. After I got those problems fixed I started having problems with the starter engaging with the flywheel and upon inspecting it, not only was the flywheel a mess, but whoever put the starter on had stripped out the holes for the starter and tried to heli coil it, needless to say, that has not lasted long and I think I just need to replace the motor.
I am interested in keeping a 6..5l in it and would like a turbo. I have found a completely reman. motor at US Engine Production Inc. it is described as follows:DROP IN COMPLETE: Includes NEW OEM Spec Parts. Includes all Reman Long Block Parts - (Cam/Main/Rod Bearings, Camshaft, Connecting Rods, Gaskets, Lifters, Oil Pan, Oil Pump, Piston Rings, Pistons, Push Rods, Rocker Arms, Three Angle Valve Seats, Timing Chain, Timing Gears, Valve Cover, Valve Guides, Valve Keepers, Valve Springs, and Valves), Plus - Exhaust Manifolds, Glow Plugs, Injectors, Intake Manifold, Pump, Turbo, and Water Pump. It is listed as a OPTIMIZER 6500 Drop In Complete Reman. When I called them, they said they had both the side and center mounted options available.
My question is, other than the changes I would need to make to my exhaust and oil lines for the turbo, would this work for my truck? They are asking $4700 for the complete pkg. I am sure I could go to the pull a part yard and get a motor and rebuild it my self, I have built numerous gassers but this is my first diesel as well as turbo.
From the description I have given, is there anything else I would need to ask or find out about/get?
Thanks much!
Greg
Thanks much!
Greg
