harleyrkc
- 0
- 0
- Burton, MI
I scored a 550 gallon diesel storage tank and 250 gallon fuel oil tank for next to nothing. I plan to use the 550 for cleaned WMO and the 250 for dirty WMO. They came with stand but it was not worth salvaging. I plan to cut it up to salvage what I can but it was home made and I don't think it was made heavy enough, which shows in how bent up parts of it are. So my questions are what color should I repaint the tanks for proper identification? And does anyone have any suggestions on what to weld up a new stand out of?
The tank dimsions peg it at 560 gallon capacity. I used 7.5 lbs. per gallon to guesstimate the weight I need to support, which came out to 4200 lbs., plus 150-200 lbs for the tank. And the smaller tank which I plan to mount below (nearly on the ground) is around 1875 lbs., plus around 80-100 lbs. tank weight.
I'm thinking about using 2" x 1/4" pipe or tubing for the uprights with a couple X supports and a pair of cross members on the ground for a skid. I only plan on putting it about 6' high.
Suggestions?
Suggestions?
