Kempho
- 7
- 3
- Central Ohio
Hi, I'm brand new here, first post, thanks for having me. I just won an auction for 2 very low hour MEP-803A generators on an M103A3 trailer. The inspection report said that the one with lower hours (17) wouldn't crank so I hooked up a couple of batteries and hit the dead crank switch, it cranks fine. When I go to the console and turn the master switch to prime/run the indicator says no fuel which makes sense why it wouldn't crank for them. Can I fill the fuel tank from the aux fuel port because the filler is hard to get to on the trailer? If so, what size and flavor is the aux fuel fitting? Also, I know they are battery related but I don't know what the black taco shaped piece is in the attached picture if someone can tell me please? Any other pre start tips or tricks are also welcome. Thank you!
