Howdy All,
First post here but I've been reading and enjoying y'all's stories, projects and events for a while now. I'm in the DFW area of Texas and would like to get acquainted with some of the enthusiasts in my area and any part sources near me. I had the opportunity to inspect and test drive 8 different trucks from one seller m923, m931 and a few duces. I chose a m931 tractor with 8.3 super singles ctis. It had 3 reman tags 2003 2007 and 2010 not sure where to decode/translate id numbers on them to figure out what exactly was done and when. Although i noted that several brake lines had been replaced some what recently as they didn't have paint on them and I inspected for leaks with none found and pressure reading at operational psi. I had a buddy walk beside the truck to listen for dragging or locked up brakes and all checked out ok. Let it warm up and lot drove it for quite a while and I Was very surprised at how smooth it ran and shifted! I also got to drive a few nhc 250 powered trucks and I really liked the spool up and top end pull of the 8.3 even with the slow roll off the start. It's a plus that I've had several chipped/tuned turbo diesel trucks f350 7.3, f250 6.0, f250 6.4 f250 6.7. Looking forward to starting to mod and clean and start resto. I've read through the -10 manual and read up on brake maintenance. What inspections or maintenance/fluid change do some of you do before a decent (70 miles) drive home with a "new to you" 5 ton. Could any one tell me if there is a thread covering basic tools needed for road side common failures or fixes? I'm not even sure if these are primarily standard or metric. Torx or Allen/hex head fasteners? Anyone interested in meeting me one day next week in north Fort Worth to do a walk around/ inspection before I make the drive home? I'll toss ya a good bottle of whiskey and a nice cigar! Is there anyone in north Texas with a good Goodyear at-2 16r20? I need a spare...
Thanks for your time and if you could answer one or more of my questions it would be much appreciated!
Paul
Paul
