ThatXJGuy
- 0
- 6
- Riverton, Wy
So I just picked up my first MV about two weeks ago, so I'm learning quick and one thing I'm not learning is where to find much info on the older trucks specifically about the R6602 like I have and all the original 1962 stuff my truck has like the "triple fail" compressor that I have. I just brought it into the shop today and am going to be starting on it in less than 12 hours now...
So for the Questions:
What brake fluid should I use? The TMs mention some silicone military part number that I have no idea how to look up. I would assume that Dot 3 would be it but assuming gets me bad places sometimes.
Where is the alcohol/methanol inlet for the air system or is there one? Haven't found one yet and I'm not sure there is one.
Are there any motor oils or gear oils that shouldn't be used with one of these (synthetic/non-synthetic, detergent/non, etc.) and are there any that you should always use? I know what weights to use in the engine and axles according to the dashboard but it sure isn't specific about anything else like the transmission or transfercase or what grease to use for the chassis or anything other than military part numbers that I don't understand.
What pressure should the mechanical fuel pump put out? somebody went and added an electric 12v pump at the tank but they still run it through the mechanical and I'd like to test the mechanical pump to possibly see why they did that.
I'm sure there will be more that i'll have after tomorrow but that's all I can think of now. I'll keep searching TMs as well but I don't know what to do when I run into these military part numbers or specialty tools. If they gave a description or something that would be great but so far I haven't found any.
Any info would be greatly appreciated, Thanks in advance!
Mike
Mike
