Datalogger
- 0
- 1
- PA
Did you ever get it up and running correctly?
It’s supposed to lube up the valve train. Don’t know if it works but it shouldn’t hurt anything. It does make quite a smoke show though.Is it April ?
A quart of ATF down the intake manifold. That can't be good? Can it?
Fuel injection or hydro shock, CAMO
Ouch, they took you for a ride on that IP if that was a rebuild (buying a 2nd, new pump should be worth that price). Diesel Care & Performance rebuilt and recalibrated my DB2 for about $300. Very professional quality rebuild that had all the right evidence of doing it right, plus the performance spoke for itself.The valve covers came off and I had two stuck valves. I figured I already sunk 1,500 into a new DB2 IP, lets keep going and ship it to the machine shop. Currently magna fluxed and is bored 30 over, just waiting for an engine kit while the heads are being rebuilt.
I don't have the tube on from the manifold to the air cleaner. Would this make a difference with the diesel dripping from the bottom a air filter cannister rubber boot? I also going to look at valve that is behind air cleaner, I think it is some type of one way vent valve, it small and is connected to a rubber hose.
