Trecker
- 4
- 3
- Germany - Lower saxony
Hello together,
I have an M934A1 here in Germany. On motor start I noticed that oil pressure needs at least 10 seconds to start to build up. I the truck was standing for days/weeks it takes even longer.
Investigating this problem I found oil from high pressure side returning throught the pump back into oil pan. The oil filter housing is only filled to a third after some time standing. I could not find any part that could prevent this issue in manuals.
So I have following questions:
1. Is this the time for building oil pressure normal?
2. Is it normal that oil can flow back into the oil pan?
3. What can I do to solve these problems?
Oil pressure is perfectly normal after start-up and under hot conditions, so the oil pump should be ok?
I would be thankful I somebody can help me with this problem!
Greetings from Germany
