Did you pull the gauge cluster to swap the bulbs or just reach up to do it? The big plug on the back of the cluster, the copper leads on the cluster, the ends that have to be clean, the holder, the contacts on the holder and the bulb all could have an effect on if it lights up or not. Plus the whole why is the alternator working when the light isn't thing?
I would suggest pulling the gauge cluster and pulling every bulb holder off. Clean with a scuff pad or small file all light contacts, the holders and check with a 12V source every single light is working. Then, put the bulbs back in and verify they light up from the contacts at the big plug input. Plug the cluster back in and see if it works then. If not, follow the big and small brown wires which are the Gen 1 + and -.
