NTC 350 Turbo VT50 Rebuild kit?????
2,906
I forgot to mention something, the solenoids will need to be changed out to 24vdc ones. the automotive 350 was most likely a 12 volt engine.
wcuhillbilly
Devils Tower, WY
I thought about this, but the jake switches are also 12v, thus Im going with the 12v solenoids and wiring the setup on its own 12v lead from the dedicated 12v fuse block off a single battery. side note, the intake heater plug on the military 250 is 12v as its wired directly from a single battery to the switch then to the intake. I thought this kinda strange, but it really doesnt do much good anyhow. and the new intake and aftercooler dont have any provisions for it yet... thinking of putting a Cummins grid heater from a 5.9 or 8.3 in the intake inlet if I could fab something up... kinda need this beast to start in the winter.
Will, any luck finding that book,?????
2,906
Switches don't care if it is 6, 12, 24, 36 volts. I forgot about looking for it. i'll go out to the garage now
wcuhillbilly
Devils Tower, WY
For closure on this thread, I did get the jakes and turbo on, Look for a thread in the 5 ton Hot Rodding/ Mods section "M816 Jakes and Turbo"
Thanks to Will for his insites and advice.
