yolner
- 68
- 28
- Rockville, MD
I just wanted to share a few things I learned while adding bushings to my hinges. First, look over the original ODIron PDF to get the basic idea of what you're doing. Now here's what I did differently.
Supplies:
5/16" cobalt bit
3/8" cobalt bit
3/32" cobalt bit (for grease fitting)
#1 cobalt bit (for grease fitting)
1103K31 grease fittings (mcmaster carr)
nylon flanged bushings - $1.35 each and 2 per hinge (https://www.motionindustries.com/productDetail.jsp?sku=00000917)
In the ODIron instructions he says to drill out your male side of the hinge to 25/64. Unless the dimensions of the bushings changed since he wrote the guide that's not correct. Opening it up that much leaves the bushings loose. I used a 3/8" bit and that gave it a good tight fit.
Next I wanted to add a grease fitting. To do that I drilled a 3/32 hole into the hinge. Then I drilled a #1 hole .175" deep and inserted the self tapping grease fitting. When drilling into the hinge make sure you take small pecks and don't push too hard. It's easy to break a bit off and ruin the part.
The female side I drilled to 5/16" per the instructions and then opened up the spacing to 1.305 to allow the bushing collars to be inserted.
You can see the final product below. Just need to put a grease fitting cap on it.
Supplies:
5/16" cobalt bit
3/8" cobalt bit
