With summer rolling around it’s time to get the A/C working. This is an 1152 ECV truck.
Is there a TM that outlines the full circuitry and troubleshooting steps?
So far I know the heater works, hi low fan works (albeit inversed, low is hi and hi is low).
The only feedback I get from A/C switch activation is the Thermopower solenoid near the coolant overflow tank. A/C on the solenoid is retracted. Heat on the solenoid is extended. Not sure if those are inverted too?
What I am not seeing or hearing is any feedback from the compressor kicking on or off. I observed the condenser and A/C gear under the passenger side rear fender near the fuel filler and have never seen the fans kick on or off or any feedback of any kind.
Any thoughts on where to begin or a full TM for A/C troubleshooting? I have no issue following wires with a multimeter but need to know where to look.
Thank you!
Thank you!
