Oil in the with the fuel
REDWOLF
Risingsun Maryland
I have been running 2 cyle oil in my m1009 when i fill up but i have a line on some cheap motor oil not waist oil fresh never used in quart oil contaners. Could i use this in place off the 2 cycle oil in the tank. Would it matter what wait it was? Would i have to fillter the new oil sence it has never been used?
CROM
Des Moines, IA
I've got to add on here....what type of used oil is OK? I've got a whole bunch of 5W-30 from past oil changes on the wifes car. If I filter it well enough and mix with some diesel, can I throw 'er in the tank and save a few bucks?
rnd-motorsports
Evart,Michigan
I use motor oil mixed with diesel with no side affects ! new oil just put it in! ,used oil I run threw a filter then dump it in with diesel fuel. I run about a 60% diesel and 40% oil in the warmer mouths with no side affects I have a spin on fuel filter rated for 5 micron rating I change it about every 4 th oil change. the oil makes the $4 dollar a gallon go alto farther . I do not see any difference in waits but would mix a little less if you use like straight 50 wait, 10w30 or 10w40 or less no problem when mixed with fuel really thins down that my opion I like the cheap fuel!!! [thumbzup]
