cucvegas
- 12
- 8
- NW Arkansas
I replaced the oil pressure gage and transducer on a 1993 Humvee with 6.5L GEP (transducer and Gauge were bad).
When startting cold, the oil pressure is reading 45. When it gets hot the pressure gets much lower (around zero) and fluctuates. Tempuratrue is around 200 when revving it hard in neutral.
I did not change the oil when I bought it a year ago, and I’ve only gone 350 miles in one year, so the oil may be very old and thin.
Should I first just change the oil, and is there a thicker oil that may register better?
I have a Fram PF5 filter from my cucv and 2 gallons of Supertech 15w40. Any other filter and oil suggestions?
When revving the engine really hard it looks like very minor heat waves coming out of the oil fill, but no smoke and it does not rattle the fill cap when it is placed on it. So maybe very minor blow-by.
The engine main seal has a minor leak when parked with oil drops about the size of a couple quarters, but the Oil level is fine. Very black, though and needs to be changed.
Thank you for all your advice!
