- 34,012
- 1,807
- 113
- GA Mountains
Good or bad luck, I'm not certain. The other day I started the SECMish CUCV to be treated to a big red idiot light telling the idiot that there is an oil pressure problem. Today I finally switched out the sender but still had a warning light. Hooked up a gauge and confirmed the worse. Odd that it was working fine when parked. I hope to start looking into it later this week. First thing I'll do is pull the vac pump and check the drive. If that pans out I'll try running up the oil pressure with a drill. If all else fails, drop the pan. Crap, this isn't the time.
