- 10,350
- 75
- 48
- Meadows of Dan, Virginia
Got a bit of a problem with my oil pressure I think.
I usually run with Texaco Ursa 30 weight, but after the new oil seal installation, I used the Shell Rotella 15-40 (from Walmart).
This is what happens: Right after starting the engine in the morning, the pressure shows about 40 psi. After 1/2 hour or so it drops to 25-30 psi and finally when I have been on the road for a while it drops to 15-20 and stays there for the duration of the drive.
There is plenty of oil in the crankcase and new oil filters (WIX 1133) were installed in Oklahoma, which had no effect.
I have been driving at least 2,000 miles like this and will change back to Ursa 30 weight ASAP.
Looking for comments.
Thanks.
Thanks.
