fallen
- 1
- 16
- Meclenburg county nc
After I got the lifters freed up I tried to crank the engine. That’s when I found out problem #2. The oil seal at the canister blows out. I purchased a conversion to use a screw on filter. It works great. I also called bill Watson and was told to make sure the valve going to the carb. pipe is open as well as the other crankcase vent tube. I cleaned out the vent tube and made sure the valve was open. The oil seal still blows at the spin on filter. You can actually see the filter loosen up a slight, while cranking engine, before the seal blows. Has anyone had this happen. I really would like to get the mule going before it snows. Any help would be greatly appreciated. Can anyone tell me where i can actually check the oil pressure at.
I am using the correct screw on filter. It is the same on that is used on the 318 engine. It is tightened properly and the crankcase is not over filled.
