- 2,892
- 1,520
- 113
- Czech Republic
I have been told the old long deuce air pack and the 5-ton air pack on the M39 are interchangeable, or better, you supposedly can use the long deuce air pack on the 5-ton.
From the 2014 GA Rally, I brought home a Deuce air pack, since I have problems with my brake system, including loosing dot 5 fluid during prolonged standing without visible leaks.
Left the 5-ton, 2x right the long Deuce AP Looking at the two next to each other (more or less), they are definitely different, and the 5-ton is bigger. Does the 5-ton version provide more fluid/power to the brakes?
If the Deuce provides less, I certainly will not change them. Also, I am thinking of opening both and check; I have to redo the current system and I do not really trust an air pack laying around in a damp area for three years.
If both are ok, I was thinking to use them together as two APs in a dual brake circuit. That is enough planning and puzzling already, two unequal air-packs might complicate things and not be a good idea.
