Blackbear
- 1
- 18
- Houston TX/ London Ky
Welcome From Houston!
was it firing before the relocation? Is it cranking slower than normal?Hey HETvet,
Wondering if you could point me in the right direction on an issue I'm having with a M1070. I was relocating the shut off switch for the batteries and grounded out the 24v side. Now I get a crank but no start. Checked the circuit breakers and relays under the dog box but I have no wiring diagram or trouble shooting info to go by. Any help would be much appreciated.
Thanks
Mark
Seems like a fuel issue to me.It was running great.Now it's spinning over good, not dragging, just no start
This is what I was thinkingMake sure the breakers are all actually good. My "DDEC" breaker got physically damaged and the truck would crank but not start. It seemed to function correctly from the look and feel of it, but it was damaged internally, I guess. Replacing it fixed the issue.
Man, you got me budCircuit breakers seem to be working. Getting power in and power out on all three ddec breakers. Getting power in two pins at ddec connection. Swapped breakers just to make sure. Still no start.
Look at the publications on here. That's the best I can come up with brotherLol, not exactly what I wanted to hear. Do you know where I could get a wiring diagram and trouble shooting guide from.
